DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Glue wood to floating chipboard? Tatami mat installation
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Author Message
jmb86
from United Kingdom
PostPosted: Fri Jul 01, 2005 10:22 pm Reply with quote
Floating floor (DPM + 100mm concrete screed + 100mm Jabolite + DPM + 22mm chip) laid icon_biggrin.gif
35mm gap all the way round needs filling with wooden floor icon_confused.gif
The mats are 55mm deep, so I had considered laying a 35mm x 55mm (ash) wooden strip all the way round the room. Question is, how do I get it to stay down? The T&G chipboard is fully glued and rock solid. I am guessing, but provided I ONLY stick to the chipboard (and not the walls, indeed, I should leave a 10mm gap and put a bead over it) then I should be okay?
There could be a difference in expansion between the chipboard and solid ash (or whatever). Would Evo gripfix be strong enough?
Or any better ideas?
TIA
jmb86
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1097 times
PostPosted: Sat Jul 02, 2005 1:13 am Reply with quote
"There could be a difference in expansion between the chipboard and solid ash (or whatever)."
Yes but not too much in the direction of the grain in the ash. You need a wood scientist to tell you the figures!
"Would Evo gripfix be strong enough?" Probably, though it's a bit thick. PVA or woodworkers Yellow Glue would be easier.
Try a woodworkers forum?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 212 times
PostPosted: Sat Jul 02, 2005 9:54 am Reply with quote
Normally you only need a 10mm gap between wooden floor and wall. Since you're only installing a wooden frame of 35mm wide there is not really a need for an expansion gap.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
solid wood installation 9 200 Thu Jun 21, 2012 8:01 pm
installation of solid wood floor - what is correct base? 4 1100 Wed Oct 24, 2007 8:11 pm
laminate flooring installation issues 2 120 Thu Dec 13, 2012 9:51 am
Carpet installation on stairs 14 220 Sun Nov 11, 2012 2:00 pm
Installation advice for 18mm t&g loft boards needed 2 140 Wed Sep 19, 2012 10:53 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
