Select 920 for Diplomat Double Oven - Main Oven not working
23 Jun 2011
Hampshire
Following a recent power cut the main oven is no longer working. Oven light bulb has blown and fan is not working. The clock and small oven and grill are working ok. I don't know much about electrics. Would the main oven and small oven be on separate circuits or have separate fuses ? Any ideas as to what is wrong and and is there a simple fix ?
Have you set the timer ? If so have you an A or Auto illuminated on the timer ?
Have you set the timer ? If so have you an A or Auto illuminated on the timer ?[/quote] :D
Can't believe it was so simple. Thanks very much ! :D
