DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Block Paving Drainage Channel (With Pics)
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
planemad
from United Kingdom
Thanked: 19 times
PostPosted: Sat Jun 25, 2011 7:42 pm Reply with quote
Hi All
Due to the small area of block paving in my garden falling slightly towards the house I have purchased some clarke drainage channel.
What is the best way to connect this into the 4" plastic drain that is already underneath the paving (there was a push fit gulley in this 4" pipe but I popped that out to take a look at the set up).
As seen in one pic there look like there is 4" cut out, is there a direct way of connecting to the bottom of the channel and popping it straight into to 4" pipe under the paving?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1232 times
PostPosted: Sun Jun 26, 2011 6:53 am Reply with quote
It looks like one of these......
.....in the image, with one of these pushed in the top....
...perhaps?
Fit one of these....
....instead.
Back to top
 Alert Moderators
RedHerring2
from United Kingdom
Thanked: 151 times
PostPosted: Sun Jun 26, 2011 9:18 am Reply with quote
If you no longer needed the drain grid, you could connect straight down into the gully from the drain channel with the correct connector.
You really do need a gully between the channel and the pipework proper to collect silt, etc.
With Noseall's solution you will always have access to clean out the gulley and for rodding, assuming there is access at the moment. Whereas a straight fall into the gulley would minimise access in the future.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Linear drainage channel - recommendations for finish 2 780 Mon May 25, 2009 10:54 am
Linear drainage channel end plates - NICE 100 brand ?? 2 60 Wed Nov 02, 2011 8:11 pm
Drainage Channel 6 200 Wed Jul 18, 2012 7:41 am
Channel in ceiling - tips? 3 40 Wed Feb 27, 2013 12:16 pm
How to decommission unused manhole channel? 3 100 Sat Mar 24, 2012 8:19 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
