I have a new seperate cooker and hob, rated at 2Kw and 6.2Kw respectively. With a total output of 8.2kw, I would need a 45amp Breaker. However, I have read that you do not have to account for the total power output as you never operate at this level and as such you can reduce the theoretical output by 1/3. Is this true, if so could I use a 30 or 32 amp breaker for my appliances? If not and I use a higher rating breaker, eg 45amp, can I use the existing 6mm2 cable which I have in place? Thanks
