Can anyone give any guide lines on how to repair a pcb for the Potterton Suprima 50. I am now on my third board, apparantly this is a common problem with these?
Joined: 12 Jan 2006 Posts: 2 Location: Kent, United Kingdom Thanked: 0 times
Posted: Fri Jan 13, 2006 7:44 am Post Subject:
can anyone explain how to fit new pcb on suprima 60. i saw new replacement kit 5111603 on ebay. is it easy job as like changing motherboard on computer.
Joined: 21 May 2005 Posts: 899 Location: United Kingdom Thanked: 7 times
Posted: Fri Jan 13, 2006 7:40 pm Post Subject:
Kit comes with full instructions on how to fit it its a bit more difficult than justy changing board though as the kit involves replacing the complete wiring harness and taking the room sealed cover off to get wires in
Joined: 22 Apr 2005 Posts: 17 Location: United Kingdom Thanked: 0 times
Posted: Fri Jan 13, 2006 9:39 pm Post Subject:
Why give Potterton anymore of your hard earned cash without trying to repair the old board first?
Remove the board and inspect all the soldered joints with a good magnifying glass. You're looking for circular hairline cracks round the joints. Pay particular attention to the joints around the diodes at the centre of the board - these were causing random lockouts on mine. Also check joints around connecting pins - these caused mine to randomly switch off the pump (with the boiler still running).
Re-solder any joints that look suspect.
Mine's run perfectly since my last repair 3 months ago (touches wood), but if it starts playing up again I'll be replacing the whole boiler with something not made by Potterton or Baxi.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
