You should have a valve like this to supply your machine then it can be isolated seperate to the cold tap.
Anything can be capped off.
But you should not leave a flexible hose pressurised on a long term basis if not in use. They have been know to burst!
But what? how is yours connected?You should have a valve like this to supply your machine then it can be isolated seperate to the cold tap.
Yes, it would be easy if one of those had been fitted but....................
3/4" brass plug, as a belt and braces approach along with shutting off the
appliance valve, which you ought to get fitted ASAP.
FFS!!
Just fit one ,It will probably cost less than a cap nut.
I need to remove the dishwasher for 2-3 days to do some work on the wall behind it.
