DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Concrete cure time for fence post?
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
1SilverBadger
from United Kingdom
PostPosted: Thu Jul 07, 2011 7:24 pm Reply with quote
I have put in a new fence post in for my dad. The hole is about 500mm, the gate is 5ft by 3ft, but quite heavy. I filled the hole with cement and sand 1 to 4 wet mix. How long should I leave the post before attatching the gate?
Thanks.
Back to top
 Alert Moderators
mointainwalker
from France
Thanked: 200 times
PostPosted: Thu Jul 07, 2011 7:34 pm Reply with quote
Wide or deep ?
Haven't done this particular exercise myself, but that sounds far too shallow for the gate if 500 mm deep ( by the way please confirm if gate is 5 h x 3 w . A little bit of annotation saves a lot of questions )
Back to top
 Alert Moderators
1SilverBadger
from United Kingdom
PostPosted: Thu Jul 07, 2011 7:40 pm Reply with quote
Yes the hole is about 500mm deep, and about 1 ft wide. it's a 3" post. Yes the gate is 3 ft wide by 5ft high. I hope the hole is deep enough, really can't be a***d to dig it up again!
Thanks.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1272 times
PostPosted: Thu Jul 07, 2011 9:12 pm Reply with quote
1 day
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 326 times
PostPosted: Thu Jul 07, 2011 9:20 pm Reply with quote
When you say sand, did you mean ballast (sand/stone mixture) or just sand?
In any case it'll fall over, the post really needs bracing against something like a wall. Or another post on the other side with a crossbar between.
Back to top
 Alert Moderators
1SilverBadger
from United Kingdom
PostPosted: Fri Jul 08, 2011 7:01 am Reply with quote
Thanks for the replies. The post is not free standing. It is conected to a wall by 3 lengths of arris rail (the wall is about 500mm away. I just used a mortar mix, rather than concrete, should be ok?
So about 1 day should do it? Seems rather short.
Cheers.
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 326 times
PostPosted: Fri Jul 08, 2011 12:45 pm Reply with quote
Mortar mix is for building walls, should've used a bag or 2 of postcrete (rapid setting concrete for fixing posts)
Fingers crossed, see how it goes, but if it becomes loose you could end up digging it out and throwing some crete in there. Either the postcrete or 5:1 ballast/cement.
(sounds harsh but the fact that you used mortar means it will dig out a lot easier than real concrete)
Back to top
 Alert Moderators
1SilverBadger
from United Kingdom
PostPosted: Fri Jul 08, 2011 1:30 pm Reply with quote
Yes. Using mortar was a fairly massive oversight! Don't for the life of me know why I did that. Oh well, fingers crossed as you say. I am hoping about 4 days is a suitable time to leave the mix to cure well. Does that sound appropriate?
Cheers.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
How long does it take for concrete to 'cure'? 20 7300 Mon Sep 27, 2010 10:24 am
Cure for gap between DPC & DPM? 9 540 Thu Apr 02, 2009 4:51 pm
best way cure a damp bath ceiling 8 420 Tue Jun 01, 2010 2:07 pm
Need to cure condensation 2 140 Mon Dec 12, 2011 3:27 pm
Condensation cure? 3 460 Tue Oct 17, 2006 9:03 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
