Hi, I have been asked to assist in a local Scout Group extension with the mains wiring which is not a problem, but the spec I have drawn up involves the new building to be added to the existing XM6 alarm. I have downloaded a manual but need some advise on how to disable the system so that I can open the cover to look inside and suss out what colours have been used for tamper and monitoring. If I enter the engineer code will this disable the tamper circuit. Also has anyone got an idiots guide on how to wire this up, what is the best door/window magnets to install and can I use 4 core BT wire as I have a lot of this.
Thanks in advance.
Thanks in advance.
