fittings for brackets into thermalite/bres blocks
15 Jan 2007
Bristol
hi..im trying to fit some brackets onto therm/bres blocks..the brackets are going to take approx 80kg of weight over two two brackets..
is there any good fittings out there that i could use..?
due to the 8cm coach bolts that i have used are pulling out under the weight..!
any help/advise would be great
regards john
I think the bracket is too short.
You need to have a brace of some sort.
You fitting a "floating shelf"?
