Installing Swivel LCD TV Bracket
14 Jul 2011
Devon
I want to install (or more likely get someone else) a tv swivel bracket for my 37" tv. The wall it will go on will be an outside wall but it does have plasterboard and studs in front of it so im not sure how far away the actual load bearing wall is from the plastboard. As you can probably tell im not too ofay with all this but what sort of wall plugs/bolts etc would i need because im assuming if I drill right into the load bearing wall there would be some distance to go from the wall to the actual bracket. I thought about just using the studs but they seem quite far apart for the bracket im intending on purchasing.
Any help greatly appreciate.
Dave
