Running rads from wood burner DIY
18 Jul 2011
I have a wood burner in my house in Spain. It has an oven type thing on the top. I'm going to make my own copper coil to run around the top and then go through the house to run 7 radiators. I was going to put in a small header tank and pump the water round to heat the rads. Do you think the water will get hot enough to heat the rads or maybe even too hot. Any ideas welcome. Just thought I would try this before I took the plunge and buy a bio mass boiler.
Will most likely get too hot if anything, and you need to be very careful if doing it yourself as incorrect installation can lead to all sorts of nasty problems, including a steam explosion if you really cock it up. Generally these systems are done on gravity rather than pumped circulation
Thanks for that. I will run it gravity fed and put an overflow and some kind of release valve for safety. We used to have something similar in our workshop when I was an apprentice and we could get that to boil if we tried hard. If it doesn't work at least I will have the rads plumbed in for a proper wood burner/back boiler/ Many thanks.
