DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Alternator (but used for something different)!!! Help
Goto page Previous  1, 2
Post new topic   Reply to topic    DIYnot.com Forum Index > General Cars
Author Message
Peter.N.
from United Kingdom
Thanked: 216 times
PostPosted: Mon Jul 25, 2011 8:07 pm Reply with quote
Hi John
The output from the generator on the small ones is AC, they have a permanant magnet rotor and usually a three phase output but they generally have a built in rectifier and sometimes a regulator.
I have a 250 watt 24 volt wind turbine with 2 metre rotor blade assy, it gives a good output in about a 10 mph wind. That has a 3 phase output with a seperate rectifier/regulator unit and a dump load resistor which is switched across the output when the batteries are fully charged. helps warm my workshop in the winter icon_biggrin.gif
Peter
Back to top
The following user says thank you to Peter.N. for this useful post:
Burnerman (27 Jul 2011)
 Alert Moderators
Mursal
from Ireland
Thanked: 441 times
PostPosted: Wed Jul 27, 2011 2:51 pm Reply with quote
Yes John, all AC and then rectified (no output brushes) some good conversion kits on E-Bay
http://bit.ly/otiZgz
Back to top
The following user says thank you to Mursal for this useful post:
 Alert Moderators
Ricardus
from United Kingdom
Thanked: 30 times
PostPosted: Wed Jul 27, 2011 4:06 pm Reply with quote
Burnerman wrote:
We'd be interested to see how you are going to drive the alternator!
My grandad built himself one of these using (I think) the motor from an old washing machine.
Of course being my grandad it was painted in maroon and powder blue paint and health and safety was "Keep your fingers away from the belt when its running, boy, or you'll only be able to count up to nine." icon_biggrin.gif
Back to top
 Alert Moderators
Peter.N.
from United Kingdom
Thanked: 216 times
PostPosted: Thu Jul 28, 2011 8:57 am Reply with quote
They are a little notchy John but they have an umpteen pole rotor which reduces the depth of the notch. I wouldn't have thought that an ordinary car alternator would be suitable , the typical max output speed you get from a wind turbine with blades big enough to get a decent output is around 400 rpm which is OK with a permanant magnet alternator but it wouldn't think it would be fast enough for a wound rotor type.
Peter
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2455 times
PostPosted: Thu Jul 28, 2011 11:45 am Reply with quote
I guess an ordinary alternator wouldn't actually reach its cut in speed.
Back to top
 Alert Moderators
GonzoUK
from United Kingdom
PostPosted: Sun Mar 11, 2012 8:24 am Reply with quote
Hello Peter & john
I big thanks for your help so far, It's been some time I know, but have not been too well icon_cry.gif
Anyway an update, my first attempted to run the alternator failed but have not given up hope yet.
Anyway have put a backup plan in place and currently running the alternator by a 1 1/2 HP motor which the alternator once started and under load runs from an inverter, so it self-powers the motor : D
Now a quick question I want the alternator now to charge a battery bank of 12v batteryís the question is does the alternators have a built in charge control as such?
What I mean is letís say the alternator is on the car, does the alternator know when the battery is fully charged and then stop charging it or is there another bit of electronics on the car that does the charge controlling?
I have used the alternator already and can see its charging a battery but I donít want to over charge it.
Once I have this info I can finish of this project and share with pictures, may be even a little video icon_lol.gif
Back to top
 Alert Moderators
GonzoUK
from United Kingdom
PostPosted: Sun Mar 11, 2012 8:26 am Reply with quote
By the way the alternator pushes out 80 amps, and the motor only takes up 7 / 10 amps.
Back to top
 Alert Moderators
Peter.N.
from United Kingdom
Thanked: 216 times
PostPosted: Sun Mar 11, 2012 9:24 am Reply with quote
Practically all car alternators have a built in regulator, it is designed to give a regulated output of a bit over 14 volts so when the battery is low the voltage difference will cause a high current to flow, as the battery voltage increases so does the difference and the current drops, when the battery is fully charged the voltage difference is small so the current is small, probably just an amp or two.
Peter
Back to top
GonzoUK (11 Mar 2012)
 Alert Moderators
Mursal
from Ireland
Thanked: 441 times
PostPosted: Sun Mar 11, 2012 2:25 pm Reply with quote
Good to hear from you again, Gonzo
Yes that alternator in the picture has a regulator built-in. It's the black box that holds the brushes in place. So it wont over charge the 12V batteries.
About the motor/Alternator combo:
Power in = Power out + loss in the system
Voltage x Amps = Power in Watts
Unfortunately there is always loss in the system.
So you wont get FREE power?
Or if you do please let me know, I'll swim over specially to see it icon_cool.gif
Back to top
Burnerman (11 Mar 2012)
 Alert Moderators
Inky Pete
from United Kingdom
Thanked: 43 times
PostPosted: Sun Mar 11, 2012 4:27 pm Reply with quote
GonzoUK wrote:
Hello Peter & john
The output from the alternator powers the motor which drives the alternator?
Not heard of the First Law of Thermodynamics as applied to Conservation of Energy then?
http://en.wikipedia.org/wiki/First_Law_of_Thermodynamics
http://en.wikipedia.org/wiki/Conservation_of_energy
Back to top
 Alert Moderators
mysteryman
from United Kingdom
Thanked: 233 times
PostPosted: Tue Mar 13, 2012 10:46 am Reply with quote
Alternators normally run clockwise when looking at the pulley. It will charge if driven anticlockwise, but you should change the cooling fan in that case.
1970s Saab 95/96s with German Ford V4 engines drove the alternator and water pump anticlockwise off the pulley on the balance shaft.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General Cars All times are GMT
Page 2 of 2
Jump to:
Battery or alternator 19 700 Tue Jan 24, 2012 9:11 pm
Vauxhall Astra 1.7TD Y reg alternator change? 4 12120 Thu Mar 20, 2008 10:33 pm
astra alternator question 15 1980 Sun Dec 25, 2005 8:42 pm
Merc. 309D Alternator Dash Light 2 740 Tue Feb 08, 2005 1:57 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
