mcc505
Joined: 11 Jul 2005 Posts: 14 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Mon Jul 11, 2005 10:46 am Post Subject: ceiling rose |
Hi, i am replacing my bathroom light but i appear to have cocked up the configuration of the ceiling rose. Is there anyone who can help me with how i should go about rewiring it? I have had about a dozen goes and everytime the same result all the upstairs lights work with the exception of the actual bathroom light itself. I have four main wires coming from the ceiling 3 have red and black wires and one has two red wires. Help please!!!! |
jtaunton
Joined: 28 Jan 2005 Posts: 426 Location: United Kingdom Thanked: 0 times
Posted: Mon Jul 11, 2005 11:13 am Post Subject: |
If you look inside the switch for the bathroom light, does it have two red wires ?
If so, try the following:
The three cables that have red and black - Connect all of the blacks to the N terminal in your new light. Connect all of the reds together in a terminal block, either as part of your light fitting or put your own one in. Do not connect these to the L in your new light.
The cable with two red wires: Connect one of the wires to the other red wires, and the other one to the L terminal of your new light.
Might work...... __________________ Be Excellent to each other.... |
mcc505
Posted: Tue Jul 12, 2005 10:53 am Post Subject: |
Thanks I will try that and get back to u thanks again. |
mcc505
Posted: Tue Jul 26, 2005 3:43 pm Post Subject: CEILING ROSE |
It worked!!!!!!!! Can't thank you enough thankyou very much indeed.
________________________--
moderator
please note 15  |
jtaunton
Posted: Tue Jul 26, 2005 4:55 pm Post Subject: |
You're Welcome.
Thanks for the Thanks...... __________________ Be Excellent to each other.... |
