upvc door wont close
17 Jul 2011
North Kent
Hello my front door keeps catching at the bottom. If I adjust the top hinge to the right a couple of turns it does the trick but once the door is opened the next time it goes back to grinding again. Anyone know if I can do something to make the adjustments permanent?
Have you tried to adjust the door up, i.e adjust all the hinges.
Hello, I did adjust the other two and after I do it works fine. But it doesn't last. :unsure:
door needs toe and heeling properly to jack it up to prevent it from dropping all the time common problem bad fitting cheers
