Boarding floor and rafters - air circulation advice
7 Aug 2011
Wolverhampton
Hi there
We've moved in to a house with clay tiles fixed on via mortar and - naturally enough, I guess - no felting. This means that the loft has got super-dusty over the years.
We're going to board the loft floor, and because of the dust, the plan is also to board the rafters, as a way of controlling the dust. We'll also add in some insulation between the rafter boards and the tiles/mortar to help with the house's heat retention, but I could do with a spot of advice about the following:
1) Is there much of a risk of messing with the airflow in the roof by adding rafter boards and getting damp/mould etc up there?
2) The house is about 100 years old and the loft floor joists aren't super-deep. I'd guestimate around 4-5in (100mmish), but I need to check. Is there any reason NOT to pack in a good 200-300mm of insulation there? Does it need to be left unpacked to insulate better (more air, etc etc)? I ask because I'm not sure how much to buy. The loft's around 9m by 9m.
Cheers
Steve
Thanks for the pointers, folks.
We're building up the rafters so that when I board across them, very little of the 200mm of insulation will be compressed, because I know that the air in the insulation is mostly what makes it work (just didn't think it through enough).
I'm definitely not going down the plasterboard route either -- I'll be seeking out some breathable membrane, I reckon.
Looking forward to getting it all finished!
Cheers
Steve
