DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Unable to watch tv channels through my Sony DVD recorder.
Post new topic   Reply to topic    DIYnot.com Forum Index > Audio Visual
Author Message
didgeradoo4719
from United Kingdom
Thanked: 2 times
PostPosted: Mon Aug 08, 2011 1:15 pm Reply with quote
I have a Sharp 40 inch Aquos TV, model no. LC40 LE 700E and I connected my Sony RDR GX210 DVD player/recorder to it via a scart lead and a tv in and out lead. I can watch DVDs via the tv from the dvd player, but I cannot view any tv channels through the dvd player/recorder. I have tried several times to run the setup and download all the freeview channels but I just get a fuzzy screen whenever I select a tv channel. I have also tried to manually install the tv channels without success. Please help! Thanks.
Back to top
 Alert Moderators
CynicalSoul
from United Kingdom
Thanked: 2 times
PostPosted: Fri Aug 12, 2011 10:44 pm Reply with quote
More than likely you just have the aerial leads connected incorrectly.
Make sure that the coax leads are:
AERIAL ---> DVD INPUT
DVD OUTPUT ---> TV INPUT
This might seem obvious but you'd be surprised how many times this happens.
If you are getting TV channels show up fine on your TV but not your player I would guess that the lead coming from the aerial goes straight to the TV and the other lead is just looped from input to output on the DVD player.
Back to top
 Alert Moderators
didgeradoo4719
from United Kingdom
Thanked: 2 times
PostPosted: Wed Aug 17, 2011 3:22 pm Reply with quote
Thanks for your reply. I have in fact connected the leads as you have indicated, but I still cannot see a picture on the TV through the DVD player/recorder. I've tried using 'Set up' via the DVD remote and also tried setting the tv channels up manually, but neither method has worked. I can view a pre-recorded DVD but that's all. Would you think connecting my SKY + HD box to DVD to TV and using the HDMI connections make any difference?
Back to top
 Alert Moderators
CynicalSoul
from United Kingdom
Thanked: 2 times
PostPosted: Thu Aug 18, 2011 11:08 am Reply with quote
As you now mention a sky box, do you have an aerial connection at all?
i.e. On your TV can you watch BBC one with the sky box on standby?
Back to top
 Alert Moderators
didgeradoo4719
from United Kingdom
Thanked: 2 times
PostPosted: Mon Aug 22, 2011 10:17 pm Reply with quote
Sorry for late reply. I probably didn't explain my problem properly. I cancelled Sky, so disconnected the Sky HD+ box and just have my Sharp Aquous TV connected to my Sony DVD player/recorder. I want to be able to record TV onto DVDs but I can't get a TV channel to show through the DVD recorder as I used to be able to do when I had it connected to a Sony TV (old style box type TV). Hope you understand what it is I'm trying to do! I have a scart lead from the DVD to the TV as well as the aerial lead from the roof to the DVD 'IN' and another lead from the DVD 'OUT' socket to the TV. Still not seeing anything on the TV when I select the EXT 1 or 2 on the TV controller.
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 652 times
PostPosted: Tue Aug 23, 2011 8:27 am Reply with quote
did you watch it on the old tv via the scart or did you have to use a channel button tuned into the dvd aeriel output??
Back to top
 Alert Moderators
Sam Gangee
from United Kingdom
Thanked: 108 times
PostPosted: Tue Aug 23, 2011 3:38 pm Reply with quote
Does the Sony DVD have a Freeview tuner?
Back to top
 Alert Moderators
ericmark
from United Kingdom
Thanked: 457 times
PostPosted: Wed Aug 24, 2011 7:04 am Reply with quote
There are a number of reasons why it may fail.
One is the TV and DVD using the same system? I have found my Blu-ray player when connected to my DVD recorder defaults to US system not UK system in may case TV will work with either.
The is also the problem in using a channel already in use. With old analogue it was easy to see the problem but with mixture of analogue and digital easy for one to interfere with other and not realise.
It could even be the TV needs setting for analogue when watching through DVD box.
Back to top
 Alert Moderators
didgeradoo4719
from United Kingdom
Thanked: 2 times
PostPosted: Wed Aug 31, 2011 11:44 am Reply with quote
Hi. I used to switch the DVD recorder on and it automatically found it via a scart lead. I've decided to disconnect it now anyway, but thanks for trying to sort it out for me!
Back to top
 Alert Moderators
ChrisFrost
from United Kingdom
Thanked: 190 times
PostPosted: Wed Aug 31, 2011 2:02 pm Reply with quote
Sam Gangee was on the right lines. This recorder has only the old style analogue TV tuner (channels 1-4 + 5 if in an areas that receives it). It doesn't have a Freeview tuner.
The West Country TV transmitters have all completed the switchover from analogue to digital. Any reception or recording devices without a digital tuner will just get snow when the tuning process is tried. That's didgeradoo4719's problem
Adding a freeview box and dedicating it to the Sony recorder is one solution. A new recorder with freeview tuner is another. If the Sky dish and Sky box is still available then a one-off payment for a free-to-view satellite card will work also.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Audio Visual All times are GMT
Page 1 of 1
Jump to:
DVD recorder unable to record channels please help 5 760 Sat Oct 31, 2009 10:40 am
unable to see or play 4 120 Mon Dec 26, 2011 8:44 pm
Loss of program guide on Sony DVD recorder 7 180 Sat Mar 31, 2012 11:59 am
my TV get all digital channels but not my freeview recorder? 7 240 Thu Jan 10, 2013 5:12 pm
HOW TO RECORD FREEVIEW CHANNELS ON PANASONIC DVD RECORDER 3 1860 Fri Jul 10, 2009 9:12 pm
DIYnot
