DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wiring to fit a tank termostat
Author Message
crocks
from United Kingdom
PostPosted: Mon Aug 08, 2011 10:25 pm Reply with quote
I am trying to fit a tank thermostat to my hot water tank. it is an immersion tank and seems to heat up extremely hot so I trying to control the temperature with the tank stat. It is a siemens stat and the immersion is controlled by a mechanical timer switch (make unknown sorry!) is this a simple fix?
Back to top
 Alert Moderators
EFLImpudence
from United Kingdom
Thanked: 614 times
PostPosted: Mon Aug 08, 2011 10:42 pm Reply with quote
Do you mean to control the immersion heater or
The heating by a boiler?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 716 times
PostPosted: Tue Aug 09, 2011 1:39 am Reply with quote
The immersion heater already has a thermostat inside it. Maybe you should test and change that if it is faulty.
Back to top
 Alert Moderators
AndyPRK
from United Kingdom
Thanked: 23 times
PostPosted: Tue Aug 09, 2011 5:22 pm Reply with quote
or adjust it down.
turn the power off, and remove the top of the heater. (usually a nut)
Inside should be a dial, maybe set at 65. You could turn it down to 60.
or as said it could be faulty.
To test, after the heater has been on for a while and water very hot, listen to the tank with the heater on.
Does it sound like a kettle, either constantly or intermittantly. If it does it's faulty.
Back to top
 Alert Moderators
dcawkwell
from United Kingdom
Thanked: 403 times
PostPosted: Tue Aug 09, 2011 7:54 pm Reply with quote
Replace / set the immersion heater thermostat.
You should be able to change the setting and heat the thermostat switch
on and off.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Termostat 5 160 Sat Feb 11, 2012 11:42 am
Storage Tank / emmersion heater wiring 41 1720 Fri Apr 29, 2005 10:26 pm
Wiring a hot water tank with two immersion heaters 16 300 Fri Mar 09, 2012 7:31 pm
Wiring a timer into a switch for an immersion heater tank 8 240 Fri May 04, 2012 9:05 pm
connecting HW tank thermostat to wiring centre for CHeating 5 500 Tue Mar 21, 2006 2:16 pm
DIYnot
