DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vaillant Ecotec 824e F.28 fault
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Wed Aug 17, 2011 7:00 pm Reply with quote
Hi all, Today tried using the boiler for hot water and on the status lcd display it says F.28 I've read the manual off the net to see what fault it is, it says the following:
F.28 Appliance does not start: Attempts to ignite during start
failed
Faults in the gas supply such as:
- Gas meter or gas pressure detector defective
- Air in gas
- Gas flow pressure too low
- Fire protection tap has disengaged
Faults in the gas valve, wrong gas setting, igniter (ignition transformer,
ignition cable, ignition plug) defective, ionisation current
stopped (cable, electrode), faulty earthing in appliance, electronics defective
I have phoned a gas safe plumber to come and have a look tommorow how much do you think this can cost to fix the fault depending on what it is etc?
I aint had this boiler serviced since moving in house 4 years ago so id have this done same time.
I've checked to make sure my gas is ok plenty of gas coming to the cooker so thats ok lol.
This is the only thing i do not want to attempt to do myself not worth the risk, different if i had a leaking pipe etc thats a diy job icon_smile.gif
thanks in advance for any feedback
Lee
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 706 times
PostPosted: Wed Aug 17, 2011 7:35 pm Reply with quote
If boiler has not been Serviced in 4 Years
to service the boiler,
you may need Ignition electrode
Burner Door Seal
for this, expect a bill of around £100+ Vat
unless your F28 is due to something more sinister
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Thu Aug 18, 2011 9:36 am Reply with quote
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2529 times
PostPosted: Thu Aug 18, 2011 12:21 pm Reply with quote
That boiler can have leaking seals which is why its so important to have then serviced regularly!
One that had never been serviced and had still been used when clearly they should have called an engineer came to about £400. The heat burns all the plastic parts inside.
Tony
Back to top
 Alert Moderators
absolute
from United Kingdom
Thanked: 2 times
PostPosted: Thu Aug 18, 2011 12:25 pm Reply with quote
F.28 could be coming up because your regulator at your meter has had it (this will be fixed free of charge by the gas board, but will need to be identified by a gas man first). Have you tried pressing the re-set button? Also was any work being done in the road on your gas main? F.28 or F.29 will come up if gas supply is interupted.
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Thu Aug 18, 2011 5:12 pm Reply with quote
plumber came up but couldnt manage to fix it as he said he dont normally work on vaillant boilers, he seems to think it might be something to do with the fan because he reckons it doesnt sound as it should. Have phoned another plumber who works for british gas so hopefully he can test things etc
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Thu Aug 18, 2011 5:13 pm Reply with quote
I asked the plumber about the gas regulator he said he cant see it being that, no work has been done to any gas in my area. Any plumbers in south wales who are familiar with Valliant boilers? cant seem to find any Valliant engineers local in my area
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Thu Aug 18, 2011 5:54 pm Reply with quote
Hi all a british gas enginner came opened boiler up checked to see if electrode was sparking nothing there, the board is gone he said.
How much do these boards cost to supply and fit? he said he will fone me with price, id just like to have a rough idea
thanks
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 706 times
PostPosted: Thu Aug 18, 2011 6:24 pm Reply with quote
I have never known a PCB to fail on one of those boilers....
but the BG engineer is the man on site, so if thats what he has diagnosed then thats what it needs can't help with a guide to price though as I have never had to order one icon_wink.gif
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Thu Aug 18, 2011 7:47 pm Reply with quote
Hi yep at least we know what the fault is, just shame it wasnt something a bit simpler, While he fixes this i will have boiler serviced we do need a new boiler cover seal (the black insulated one) as when first plumber took cover off the seal was crumbling away.
Back to top
 Alert Moderators
SpecialK
from United Kingdom
Thanked: 12 times
PostPosted: Thu Aug 18, 2011 9:07 pm Reply with quote
Can you phone vaillant and see if they have a local engineer or will look at it themselves?
Is it possible another input to the PCB is stopping the spark? Or did the BG guy seem confident about his findings?
Back to top
 Alert Moderators
Bunnyman
from United Kingdom
Thanked: 493 times
PostPosted: Fri Aug 19, 2011 9:23 pm Reply with quote
Well I work on thousands of these an never had a pcb ignition fault so I would be wary of that! Ring Vaillant for fixed price repair pcb about £180
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Fri Aug 19, 2011 10:06 pm Reply with quote
BG tested the pcb with meter etc and its got no power, the wire running to the pcb has power but soon as it enters the board theres nothing live there. Will post an update when pcb is replaced hopefully will be fine then. if it was something alot more sinister with cost wise then id prob look at replacing boiler but pcb supply and fit for under £200 is reasonable for a youngish boiler.
Only thing i dont like about this boiler is we cannot have a good dhw flow rate, ive measured 6 litres a min, takes 35 mins to fill our bath.
lets wait and see
thanks again for all your expertise
Back to top
 Alert Moderators
Bunnyman
from United Kingdom
Thanked: 493 times
PostPosted: Fri Aug 19, 2011 10:31 pm Reply with quote
should be 8 to 10 lm check your cold inlet if you got 12l on the cold you should get 8-10 lm on the hot , i presume someone has checked the fuse on the pcb 2amp?
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Sat Aug 20, 2011 8:21 pm Reply with quote
Hi yes bg guy checked everything and said its board hes come across it once or twice with same brand boiler.
DHW flow is deff only 6 lm, i had to adjust the valve feeding the boiler otherwise if it was open fully the water be cold / luke luke warm coming out of bath tap, Thats the only thing i could think of what to do. Is that normal? lol hopefully bg coming monday to replace board
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Vaillant TURBOmax Plus 824E Boiler LOCKOUT F28 Fault Code 13 6020 Sun Feb 21, 2010 12:57 pm
vaillant turbomax plus 824e - hot water fault 5 1600 Thu Dec 31, 2009 11:19 am
vaillant turbomax plus 824e 10 7240 Thu Feb 16, 2006 5:45 pm
Vaillant TurboMAX 824E problem 8 2000 Tue Dec 30, 2008 11:38 pm
Vaillant Turbomax 824E fan running when cold water tap turns 5 1020 Fri Feb 12, 2010 11:28 pm
DIYnot
