I've got an old cartridge type consumer unit and the built in RCD trips, fairly randomly.
I think its something to do with moisture in the air, tends to happen during wet periods, but it happened during the dry cold period as well last winter.
Anyway.
Since I cant really afford to have the problem properly sorted, which would in my understanding basicaly requires a rewire, its my understanding that the unit wide RCD, can be replaced with circuit wide RCBOs, so that should the fault occur again, it will only disable the effected circuit, allowing the rest of my house to continue unaffected.
Is anything I've just said even close to being accurate? And if so, is it a proper electricians job?
When I say randomly, I really do mean that, hasnt happened for at least three months, one day last winter, it went ever couple of minutes, then, with nothing unplugged or changed in anyway, it ran fine for days or weeks.
Anyway.
