Any suggestions for this problem lads.........
Security light with attached PIR picks up the heat/fumes/smoke from the boiler exhaust.
It's one of three, but this particular one is really hard to explain the circumstances and position of, so I wont ! Suffice to say moving it isn't the answer !
What i'm after is a different type of sensor to wire into existing light.
Can a sender-receiver, beam/reflector type sensor be wired into existing light fitting.???
If so.... any recommendations.????
Thanks.
Thanks.
