Not hard to get hold of LPG kits where they are available. Just do a search! If I told you where to look I would expect the Mod to delete it before you read it anyway.
Problem is you cant always just swap the bits over and expect it to work.
LPG is a different gas with different properties so unless you have the right equipment and know how you would probably find yourself with a cross lighting problem at the least.
I can only back Tony up when he implies that you dont do this yourself if not qualified.
