Chandler
Joined: 18 Jul 2005 Posts: 2 Location: Worcestershire, United Kingdom Thanked: 0 times
Posted: Mon Jul 18, 2005 7:23 pm Post Subject: Kitchen cooker Connections |
I have a separate oven and hob, do I need to have separate connections for each or can I run them both into the switched cooker switch ? |
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Mon Jul 18, 2005 7:30 pm Post Subject: |
give us some ratings and we might tell you, otherwise search the forum, theres bound to be a situation described on here that matches yours. |
Chandler
Posted: Mon Jul 18, 2005 7:42 pm Post Subject: Cooker connections |
Can't see any obvious ratings, this is a cooker hob combination being replaced with a standard single oven and a separate halogen hob. Separate fuse at fuse box rated 32.
Other treads are inconsistent in the advice some say separate some don't. Is a separtate another wire run from the fuse box or a separate spur from the origional.
Sorry not to be able to giev specifics |
Steve
Posted: Mon Jul 18, 2005 8:03 pm Post Subject: |
there should be rating plates on both appliances, stating a wattage.
If its a single oven, put it on a 13A plug or a switched fused connection unit (neater) on a ring main.
Wire the hob to the cooker switch and keep the 32a fuse. |
