Running wood burner with back boiler, vented, no water yet.
R
RedHerring2
I've recently installed our wood burner with a back boiler.
Pictures etc here:
//www.diynot.com/forums/viewtopic.php?t=237971
I'm currently installing floor and stud walls upstairs. So it's going to be a good while before the back boiler is fully plumbed in and working.
Can I run the wood burner without water in the back boiler?
The boilers are not connected to anything yet, so obviously vented to air.
I've only done a draw test on the wood burner, so far.
Thanks. Does that mean I can't run the wood burner at all until it's fully plumbed in?
Ditto mysteryman, you can't use your stove at all until the wet side is connected and filled
