Indesit washing machine fault code f-03 suggests that the...
25 Feb 2010
Please provide me with some help on this one...
On my Indesit WIE167UK have fault code f-03, I found that this means the element sensor / thermistor is faulty(NTC). I tested existing NTC and at room temp had 15Kohm, under cold water open circuit, hot water (40'c) 5Kohm ( same as a brand new one) these are approximate values. What else could be causing this fault? All the wiring is good and the washing machine was working well and has not have any fault previously.
TIA
Thanks for the reply.
I thought as much. Have you ever repaired them? I'm going to take this one's apart, been told that it can sometimes be a faulty resistor!
No never. Send it or phone emw in Nottingham they will help you out they repair them.
