Juffle
Joined: 24 Jul 2005 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 24, 2005 4:16 pm Post Subject: Radiator Pipework |
I wish to replace an ordinary radiator in my bathroom with a towel rail, but the pipework is, not surprisingly, in the wrong place - too far apart. I could either add a couple of 90 degree bends to one of the pipes or - and this is the question - can I use a flexible chrome tap fitting or a short length of Hep2O? |
doitall
Joined: 08 Jan 2005 Posts: 9933 Location: Bath, United Kingdom Thanked: 240 times
Posted: Sun Jul 24, 2005 4:25 pm Post Subject: |
if it's not far out use extension pieces |
JPC
Joined: 10 Aug 2004 Posts: 1409 Location: Leicester, United Kingdom Thanked: 0 times
Posted: Sun Jul 24, 2005 5:42 pm Post Subject: |
dia is talking about rad valves extensions......see what gap u need to make up and go and get some....
they come in 20,30 and 50mm and some are extendable (but i dont like them)
So....combining these on both sides of the rad could make up ur gap.
u can join them together ie a 20mm and a 50mm to make a 70mm...
but the longer the extension the worse it looks...it normally looks ok up to a 50 mm ext ..... __________________ Jamie |
namsag
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Sun Jul 24, 2005 9:21 pm Post Subject: |
Now that will look lovely £ 200 quid spent on a towel rad with a bit of plasic joining it up or not quite as bad a few extension pieces..... get someone in and pipe it up proper coming striaght out of floor with a couple of nice inline rad valves and make it the feature it is deigned to be |
Juffle
Posted: Fri Jul 29, 2005 2:34 pm Post Subject: Radiator pipework |
Should've said - the pipework rises through a solid floor, then expensive ceramic tiles(no longer available to replace), and so I HAVE to leave them as they are. I was advised that an extension piece, especially one with a drain plug, would allow me to close the gap.
What I really wanted to know was whether it was safe to use flexible connections, given that I shall have in-line valves which would ordinarily require rigid pipework either side.
Thanks to those who offered advice, and if there's an answer to this post, I would be grateful. |
