Hi there, I could do with some friendly advice please. I have a Chaffoteaux & Maury Britony Combi 80 (or possibly 100) and have had snags with the hot water ever since I took the rad off the wall in my bedroom in order to paint behind it. Followed careful instructions and got the rad off no problem. Unfortunately, I hadn't quite turned off the control valve all the way and I experienced some leakage around the open pipe end which seemed to get worse whenever I ran any hot water (which was taking incresingly longer to warm up). As a precaution, I turned off the hot water and have not run any since and that seemed to solve the leaking issue. Once I'd finally noticed that the control valve was not off all the way (how blonde!), I closed it fully and tightened the compression joint underneath to make doubly sure. I then noticed that the pressure gauge on the boiler was at 0 bar and so I opened the filling loop valve to top it up, like I'd been shown before I moved in. The pressure went straight up to almost over 3 bar and when I close the filling loop again, it went almost straight back to 0. I opened the filling loop once more to try again and looked out my bathroom window at the same time to see water gushing out of the overflow pipe and down my outside wall. Have I managed to somehow fook my hot water/boiler/whatever by taking the rad off the wall and not doing something else as well to prevent this happening?! Any help would be greatly appreciated.
