DIYnot
Local | Network
   DIYnot > Forums
Local | Network
fitting a plastic door
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
fliesman
from United Kingdom
PostPosted: Sat Jul 12, 2003 5:58 am Reply with quote
I will be fitting a new upvc front this weekend. i am happy about the methods used but have forgotten how to toe and heel. can anybody help??
dave
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Sat Jul 12, 2003 7:12 am Reply with quote
Make sure the UPVC door frame is absolutely level and plumb and use a straight edge for checking bow on the frame.Also check for corner to corner for square as it is very important when fitting the door.
And finally make sure your spirit level is level !!!! ( This will guarantee to stop the swearing box filling up later on ! )
You can test this by putting the spirit level on any level + upright surface and turn the spirit level round again on the same spot to check the bubble is in the same place,if not adjust the level.
Back to top
 Alert Moderators
kostello
from United Kingdom
Thanked: 1 time
PostPosted: Sat Jul 12, 2003 11:19 am Reply with quote
go here and find out
www.thewindowman.co.uk/toe_heel.htm
aleks
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
plastic door sills 3 500 Thu Sep 03, 2009 6:26 pm
Spy hole on plastic door 5 700 Sun Feb 03, 2008 1:33 pm
double glazed plastic door 2 360 Fri Mar 13, 2009 4:05 pm
Replacing upvc panel in door without usual plastic beading? 3 1160 Mon Jan 11, 2010 2:14 pm
Damaged (melted) plastic conservatory door problem! 4 880 Mon Sep 12, 2005 4:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
