Two way pull switch
29 Jul 2005
London
I am replacing a two way pull switch for a bathroom light which had worn out.
I have three red wires which are otherwise unmarked:
wire A (live) was in one connection;
wire B had come out of its connection by the time I could see it, but I from its position I am pretty sure it was in the same connection as wire A
wire C was in a connection on its own.
I am pretty certain that A (and presumably B) were in L1 and wire C was alone in COM. Does this sound right? as it is possible that it was the other way around: A (and B) in COM and C in L1.
Does this suggest that C is the switched live?
Many thanks for your help
If it is a two way switch and there are two switches controlling the bathroom light, then all conductors will need to be in individual terminals.
If the circuit is a one way system, wire it up as a one way system, but if it is a two way system, wire it up as a two way system. If it is neither then get someone else to have a look
Thank you all very much for your help.
I'm not sure why it is fitted as a two way switch, as I haven't been able to find another switch in the flat which operates that light. So I think it was previously wired as a one way switch.
The diagrams are very helpful - thanks for pointing me in this direction.
Is it usual to use the same colour for each wire?
Thanks again
No, but it is the "most correct" approach. A switch cable does not contain a live and a neutral, it has 2 lives (one permanent, one switched), and if you use red/black cable rather than red/red then you should put red sleeving over the black core, at each end, to signify that it is live.
