WILF55
Joined: 03 Aug 2005 Posts: 1 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Wed Aug 03, 2005 5:06 pm Post Subject: INSTALL A COOKER |
hOW DO I WIRE THE GREY CABLE INTO THE COOKER WALL SOCKET DIAGRAM IF YOU CAN PLEASE
I HAVE 2 LIVE 2 NEUTRAL AND 2 EARTH WIRES AND ONE OF THE BOXES WITH PLUG SOCKET AND BIG COOKER SWITCH |
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Wed Aug 03, 2005 5:31 pm Post Subject: |
1. REVERSE THE POLARITY OF YOUR CAPITAL LETTERS
2. why didn't you check your post before you submitted???
3. there is NO WHERE NEAR enough detail there for anyone on this planet to help you. |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
mapj1
Joined: 24 Nov 2004 Posts: 1040 Location: United Kingdom Thanked: 0 times
Posted: Wed Aug 03, 2005 11:30 pm Post Subject: |
Or if you would like us to try and help, and this is not a wind-up then please describe,
if your existing cooker point is fed from a 30, 40 or 45 A radial, and the type of cable that feeds it, and then the rating of the new cooker in either watts or amps. From this we can tell if your existing wiring is up to it, or if the cable needs replacing with something fatter. (many new cokers draw rather morepower than older models, and just re-using the old wiring "willy nilly" can be a fire hzard, depending what is there.)
Then we need to know the wire routing arrangement, I presume from description that it might be that you have a cooker isolator on the wall feeding an outlet plate, but maybe not as you mention 2 wires, it may also be directly wired to a tail. Then we need to know what is on the back of the cooker, screw terminals, eye terminals, studs? If it set for split phase supply it will need linking up for single, and probably other details we realise we need as you describe the problem in more detail..
Not trying to put you off, but trying to explain the previous gruff responses. __________________ regards Mike(G7VZY)
-STICKY Reference Info @ top of forum, Has diagrams & answers to common probs- |
bang
Joined: 24 Nov 2005 Posts: 7 Location: United Kingdom Thanked: 0 times
Posted: Thu Nov 24, 2005 1:25 pm Post Subject: |
is it ok to insulate a bare earth wire with standard insulation tape when wiring a electrical cooker |
Spark123
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
