Joined: 19 Jul 2003 Posts: 3 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Sat Jul 19, 2003 1:03 pm Post Subject:
line new plastered walls or paint directly onto them
i have new plastered walls do i paint or line the walls, is it best to have lining between paint and a new plastered finished wall?
thanks for the advice so far but still unsure? will it matter long term if i directly painted should i decide to paper in the future
Joined: 28 May 2003 Posts: 92 Location: United Kingdom Thanked: 0 times
Posted: Sat Jul 19, 2003 1:42 pm Post Subject:
You can paint directly onto the plaster but you must make sure that you've sealed the plaster first with PVA + water, possibly two coats -the first being thinner, say 1/4-3/4 PVA to water, the second 1/2-1/2, otherwise the plaster will simply take all the paint up and the finish will be atrocious.
I'd also be inclined to put a coat of undercoat on as well just to be sure. It seems like a lot of work but the finish will repay the effort.
If you do use lining paper you'll need to seal the plaster anyway with diluted wallpaper paste or you risk the same problems. An (apparently) it's best to put the lining paper on horizontally rather than vertically. Although I have never done this and can't quite see why this is better.
Joined: 10 Sep 2002 Posts: 765 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 20, 2003 10:46 pm Post Subject:
I have my decorators give bare plaster a first coat of diluted emulsion of about 3 parts paint to 1 part water and then it is given two coats of the desired emulsion. It tends to work very well like that.
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Mon Jul 21, 2003 3:38 pm Post Subject:
When I used to work on building site,the paint & decorators always been told to paint on new plaster as you cannot wallpapers on new plaster walls for 6 months,not sure why ?
Joined: 24 Mar 2004 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Wed Mar 24, 2004 11:17 am Post Subject:
The usual advice is not to paper newly plastered walls for at least six months to ensure that the plaster is fully dry and that any salts that may leach out of the plaster in the first few months don't stain your wallpaper.
I was advised by a plasterer to paint the walls with Wickes one coat emulsion once the plaster was dry. It only comes in white but it does a good job of sealing the surface so you can then get a good finish. New plaster soaks up paint like a sponge, it can sometimes take quite a few coats of ordinary paint to get a decent finish. Even if you intend to paper it is worth doing because you get much better slip once the surface is sealed.
If you paint the walls it is relatively easy to touch up any flakes or blisters in the paint, whereas if you paper and the paper gets stained it is a much bigger and more expensive job to put it right
Joined: 15 Jan 2004 Posts: 48 Location: United Kingdom Thanked: 0 times
Posted: Wed Mar 24, 2004 11:52 am Post Subject:
Im with Cobweb on this one. I would seal the walls with PVA mixed with water. 2 coats and it will be fine. I have done this all through my home and works a treat.
Joined: 02 Apr 2004 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sun Apr 04, 2004 7:56 pm Post Subject:
Yes, plaster needs sealing for all the above reasons - regardless of the reason why the plastering has been done. You can still get hygroscopic salts leaching out of a wall - even if it's just been damp-proofed, as it can take up to a year for wall to dry out thoroughly (an inch a month I've been told - dependant on material of wall and thickness).
Joined: 18 Nov 2007 Posts: 2 Location: United States of America Thanked: 0 times
Posted: Sun Nov 18, 2007 4:10 pm Post Subject:
what if "atrocious" happens?
Help...this happened to us..." otherwise the plaster will simply take all the paint up and the finish will be atrocious."
Our painter did not prep the wall that had been plastered a month ago and the result is atrocious...there are bumps all over. What canwe do now. Thank you so much.
[quote="cobweb";p="10680"]You can paint directly onto the plaster but you must make sure that you've sealed the plaster first with PVA + water, possibly two coats -the first being thinner, say 1/4-3/4 PVA to water, the second 1/2-1/2, otherwise the plaster will simply take all the paint up and the finish will be atrocious.
If you do use lining paper you'll need to seal the plaster anyway with diluted wallpaper paste or you risk the same problems. An (apparently) it's best to put the lining paper on horizontally rather than vertically. Although I have never done this and can't quite see why this is better.[/quote]
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
