| Author |
Message |
DELL
Joined: 15 Jan 2004 Posts: 11 Location: Kent, United Kingdom
Posted: Fri Aug 05, 2005 9:13 pm |
I have flat roof extension which was a outside toilet and coalshed. It`s roof is of the old poured asphalt type and leaks terribly into my kitchen. Would any of you kind gents tell me if I could alter the flat roof to a slight pitched roof. if so how do I go about it. all information would be greatly apprieciated.The building incidently is attached to the house and not a seperate building |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
nstreet
Joined: 22 Nov 2003 Posts: 1761 Location: United Kingdom Thanked: 1 time
| Back to top |
Nige F
Joined: 28 Jun 2005 Posts: 15464 Location: United Kingdom Thanked: 716 times
Posted: Sat Aug 06, 2005 7:48 am |
Poured asphalt? not 3 layer with chippings...The former should last longer,and only leak if you can see cracks. More info please..may not need to renew,shallow pitches tiled can be problems too. |
| Back to top |
DELL
Posted: Mon Aug 08, 2005 11:28 am |
The house is a 1940s semi and the flat roof conversion was done before I bought it. the leak is at the join between the kitchen and the conversion.
I have tried sealers and the like but still no luck. lasts about 3 months then starts to leak again.
I was advised to have a lead flashing fitted into the wall at the join as opposed to the cement one which is in existence and a rubberoid roof covering.
Ithought that a slight pitched tiled roof would be better in that the water would run away from the house. |
| Back to top |
masona
Joined: 05 Jan 2003 Posts: 12358 Location: Essex, United Kingdom Thanked: 98 times
Posted: Mon Aug 08, 2005 4:36 pm |
| DELL wrote: | | Ithought that a slight pitched tiled roof would be better in that the water would run away from the house. |
It would be better, how much angle do you think you can get away with? |
| Back to top |
Nige F
| Back to top |
DELL
Posted: Mon Aug 08, 2005 5:33 pm |
to masona
probably 45 degree into the gutter with a decent flashing
could I do it myself
| Back to top |
masona
Posted: Tue Aug 09, 2005 6:51 am |
| DELL wrote: | | probably 45 degree into the gutter with a decent flashing |
Don't have to have it that high, approximately 15 degree is the lowest.
| Quote: | could I do it myself
Don't know but will need building permission approval which is straight forward, pop down to your BCO with a rough darwing and they will tell you what to do. |
| Back to top |
