DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
kitchen sink/disposer plumbing
This topic originated from the How to page called Plumbing in kitchen appliances
Click here to return to the page called Plumbing in kitchen appliances.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
PJain
from United States of America
Thanked: 0 times
PostPosted: Sat Aug 06, 2005 1:49 pm    Post Subject:
Reply with quote Thanks
I am replacing my kitchen countertop and want to install an undermount sink which is also deeper than the current one. So I have to lower the garbage disposer. currently there is a s-trap connected to the disposer and the s-trap goes into a horizontal pipe. Can I use an L-shaped pipe between the s-trap and the horizontal pipe to lower the disposer by 3-4 inches? Would you recommend any other maximum height of the L-pipe? Any help would be appreciated. thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Sat Aug 06, 2005 4:22 pm    Post Subject:
Here in the UK the only garbage disposers I`ve come across in 35 years are broken ones that we`ve removed icon_sad.gif ...Not much use for them here.Sorry icon_sad.gif
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sat Aug 06, 2005 10:06 pm    Post Subject:
EH? Well mine works fine thankyou very much. Sounds like the grot gobbler and the sink each have their own S trap, and then the pipe goes to a horizontal. That's absolutely fine. As long as the pipes which aren't part of the trap itself are all downhill. If you have to go UP with your L shaped pipe to the horizontal one, you'll be making another trap which is, er, not ideal!
Back to top
 Alert Moderators
PJain
Thanked: 0 times
PostPosted: Sun Aug 07, 2005 2:32 am    Post Subject:
Chris, thanks for your reply. I checked again and I was mistaken about the s-trap. Actually the horizontal pipe coming out from the wall has a p-shaped pipe from which another pipe comes and goes up a few inches to connect to the garbage disposer. what do you think is the best way to lower the disposer?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sun Aug 07, 2005 7:24 am    Post Subject:
It's best if the WD and the sink have their own traps, doesn't matter which type, to reduce the amount of pipe above the water line in the trap(s). This is to reduce the smells which come up.
After the trap you'd just use whatever you need to get to the common exit.
Back to top
 Alert Moderators
tim00
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 08, 2005 1:20 pm    Post Subject:
PJ, what state are you in? The Uniform Plumbing Code does not allow S-traps. So presuming a P-trap:
when your sink is lowered the garbage disposal will lower by the same amount, hence your trap arm will find its own outlet level.
The trap arm should run into the wall and be picked up by the sanitary tee in the waste and vent pipe.
From your description you will have to open up the wall and cap the old arrangement.
Come back if the above suggestion is not feasible.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Kitchen sink plumbing 4 1280 Sat Sep 15, 2007 2:54 pm
Kitchen plumbing from sink to outside tap help 9 740 Tue Nov 15, 2005 10:51 am
kitchen plumbing and bad smells 8 180 Mon Jan 12, 2009 9:29 pm
Internal Kitchen Plumbing 2 1600 Wed Apr 04, 2007 3:35 pm
Kitchen plumbing problems 2 280 Sun Feb 18, 2007 6:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
