DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bathroom sink leakage
This topic originated from the How to page called Installing a bathroom sink
Click here to return to the page called Installing a bathroom sink.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Richard Cox
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 08, 2005 8:56 am    Post Subject:
Reply with quote Thanks
I had a bathroom installed last year and I\\\'ve recently noticed that the the sink is leaking. The most worrying part is that it\\\'s not the plug but the actual fitting is leaking, so the water is not draining into the waste pipe! Now do I just whack some sealant on to it or do I need to get it refitted? icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Paul Barker
from United Kingdom
Thanked: 19 times
PostPosted: Mon Aug 08, 2005 9:25 am    Post Subject:
Ideally it should be dismantled dried and reassebled with silicone, left 24hours before use.
Cheap to try a two pack epoxy putty around it first. This is something I have never had the luxury to use so have no idea how effective it is. The proper job may involve quite some expense depending on the instalation. Modern bathrooms are not designd for ease of maintenance, seems cad doesn't factor in the future.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Aug 08, 2005 9:41 am    Post Subject:
It's probably leaking down past the thread on the waste. They leak because there's no reason why they shouldn't. I haven't yet seen a design which tries to stop it! There are special thick washers, but they never come with the waste. icon_rolleyes.gif
If you can get at the big nut which is holding the waste fitting to the sink, undo it. Get plenty of silicone on top of it (finger round the back) and do it up so the thread is sealed against the basin by the goo. Stands a good chance of working.
Before you start, after undoing the nut I'd warm it with a hairdryer to dry it and clean what you can.
There is a special pair of pliers which helps to undo the nut, try a plumbers' shop...
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Flame leakage from boiler 9 660 Sun Dec 30, 2007 9:53 pm
Baxi Barcelona condensate leakage 2 680 Sat Mar 25, 2006 10:00 pm
Vaillant Ecomax - condensate leakage 16 1040 Thu Mar 23, 2006 12:40 pm
Leakage 14 480 Sat Jan 12, 2008 9:20 am
Leakage radiator 4 380 Fri Oct 13, 2006 1:26 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
