Salt container
9 Aug 2005
London
Hi everyone!
I've used Bosh Dishwasher for 2 years. After the indication of salt I try to add more salt. But the container is full of water. So I take out the water first and add full of salt. Does anyone know what to do regarding this problem? Or it this normal???
Thank you in advance.
As far as I know this is normal.
When you add salt it displaces the water......
Hi PFE
Thank you for your information. It helps.
Best regards.
June
Yep, this is normal. You haven't put any salt in for 2 years ?
Hi Bathjobby
Of course I use salt all the time, but I didn't know the way I doing is normal or not. I took out some water which wasn't easy and added some salt.
So when you add salt you just add some salt and it sink the bottom of the container and natually displaced. Please let me know how to do it exactly. Thank you for your reply.
Regards
Its as simple as that. You pour the salt in (most machines come with a funnel which clips into the hole to make it a little easier) which naturally displaces the water as it sinks. nothing more to do......
Hi Bathjobby
Thank you for your replay. I did this time what you told me. I used to take out water from container and add salt. Now the problem is sorted.
I found this website by accident and glad to join.
Thanks a lot and have a good day.
Regards
