Blocked Drain - I'm Going In...
19 May 2005
Sussex
The bath was running slower and there was a bad smell from the drain outside the kitchen window. I try the old caustic which worked last time but notice now there's standing water in the drain... hmmm Figure if I could just lift up the grate and get stuck in I might not need to call DynoRodders straight away - but the f*ckers cemented in!
Who in their right mind would cement down a grate - is it common? Am I going about this the right way, i.e. smash it to pieces and if it still doesn't clear only then call the Rod Master?
Cheers!
:p
To paraphrase the Kia advert.."think about it"....would you rather pay £60.00 per half hour to Dynomeister, or break the grid and plunge the drain with an old mop :) Then buy a new plastic grid for a quid. GO for IT. You got Drains in your part of Sussex..we still got Privvies :eek:
Look out drain - I'm BAAAAAAACK!!!!!!
:p
For that money I'd even consider renting my own set of rods... will see how it goes and update here should the drain scum fight back....
:p
buy a set for less than that
When I say its cemented in - having had a look again it could be the top of the soil pipe thats covered the grate, or the grate has rusted in. I do I check this baby?
Also there is a manhole to the side although it is going away from the road, it is between the bathroom (downstairs extension) and the drain - what should I expect to find there??!
Don't really want to put a crack in the soil pipe......
:rolleyes:
bpowell555 said:
When I say its cemented in -, or the grate has rusted in. LIKELY.... a manhole to the side although it is going away from the road, it is between the bathroom ..............and the drain - what should I expect to find there??!..............Richard 111 and the whole cast of Hamlet :eek: :LOL: Or If it`s a bigun ...HenryV111
:rolleyes:
NigeF were you agreeing with me? :LOL:
Will have a look under the manhole later this week. If I still don't know what to do will post pictures :)
Yes, grate prob. cemented........can you give us a clue to which part of Sussex...I`m intrigued? Not Fulking, Nr Brighton, is it...Fulking Hill? I`m fairly near God`s Waiting Room :LOL: :LOL:
What did you find there?
I know what I found under mine when I had the same kitchen drain symptoms - just wondered if you had as much fun.... :evil:
Actually it was all clear... seems the flow is ok after all. The smell is from a build up of scum in the drainhead. Probllem being the grate is cemented in so I'll have to hacksaw that out; get in with the rubber gloves then stick on a plastic replacement... Still haven't got round to it - its all in the planning!!!
First post AUG,9... :LOL: :LOL: :LOL: get some Jeyes Fluid down it. ;)
Heh what can I say, I'm fookin efficient :)
I dumped a load of caustic down there - will Jeyes fluid work?
Cheers!
