nbegg
Joined: 10 Aug 2005 Posts: 2 Location: Tyne and Wear, United Kingdom Thanked: 0 times
Posted: Wed Aug 10, 2005 8:44 pm Post Subject: MCB trips when i switch lights on but not if i use an RCD |
If i connect the light circuit on the RCD side of the bus bar they work great but if i connect them direct to a non protected MCB they trip? Any ideas. |
Adam_151
Joined: 17 Jun 2004 Posts: 4540 Location: United Kingdom Thanked: 10 times
Posted: Wed Aug 10, 2005 8:50 pm Post Subject: |
Have you got the neutral in the correct neutral bar? |
pdcelec
Joined: 05 Jun 2005 Posts: 707 Location: Birmingham, United Kingdom Thanked: 0 times
where is the neutral connected? |
andy
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
Posted: Wed Aug 10, 2005 9:21 pm Post Subject: |
what trips? MCB or RCD. if RCD, youve probably got the neutral in the wrong place, as already mentioned. if MCB, then something bad is goin on... |
nbegg
Posted: Thu Aug 11, 2005 2:55 pm Post Subject: Thanks i will try it tonight and let you know. |
I will check the neutral bar tonight |
Steve
Joined: 15 Apr 2005 Posts: 12851 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Thu Aug 11, 2005 5:30 pm Post Subject: |
neutral barS, you will have 2, be sure to use the correct one when swapping the MCB around. |
