Baxi Solo 2 30PF
10 Aug 2005
London
My boiler is not doing anything anymore. just makes clicking noises, when turned on. No firing sequence and no spark, and no lights.
Please advise on how to get boiler to work :eek:
You need to refer to Manufacturer's Instructions, which includes a fault finding chart. You can then be a bit more specific about point at which failure occurs. Quite likely that fault will relate to gas side (e.g. ignition, fan, etc.) which should only be investigated by Corgi reg. bod.
Not sure about the clicking noises but have you reset the overheat stat?
Thanks for reply.
It is not the overheat that needs resetting as this usually indicates an amber noise. No amber noise is being displayed and I tried to reset it anyway and it did not work.
I have studied the flow chart in the past but found that a little too complicated to work out.
I noticed that the ignition box with the LED lights is looose, so I gave a little pull and shake and it started to work again. showing the lighting sequence which follows the start up procedure. So I guess the fault lies with this box. I have not turned off the boiler, just in case it messes up again. what if it goes faulty again, should I purchase a new ignition box and install it? Can this be done by a DIYer or do i need Corgi registered assistance?
It could just be a loose electrical connection on control box. If you isolate electricity you could check that all plugs and connections are secure.
The solder joints do break on the pcb where the led's are. Quite a common pcb to replace really.
What does PCB stand for? Is this the ignition box with the led lights.
Cheers
Of course. Is there anything else amber worth knowing about?
