DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Metal Post Spikes
This topic originated from the How to page called Different ways of anchoring the fence posts
Click here to return to the page called Different ways of anchoring the fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
  View previous topic :: View next topic
Author Message
rbontherightside
from United States of America
Thanked: 0 times
PostPosted: Thu Aug 18, 2005 4:13 am    Post Subject:
Metal Post Spikes
Reply with quote Thanks
I would like to install a wood privacy fence in a large area using metal post spikes. How durable would the fence be compared to putting the 4x4 posts in concrete.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Thu Aug 18, 2005 6:50 am    Post Subject:
Over here they are called metpost. The metpost do cope quite well and easier if you need to change the post if it's rotted. The concrete method is more solid & stronger. What some of them do is, concrete the metpost as well but I rather use concrete post bedded in concrete instead of wooden post.
I suppose if I use metpost, I would use it up to 4' high panel and any higher I would use concrete method depending on the design of the fence panel against the force of the wind.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
bathjobby
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 18, 2005 12:29 pm    Post Subject:
If you do decide to concrete in wooden posts, make sure the concrete is tapped well into the sides of the post (no gaps) and raise the top of the concrete out of the ground level at 45 degrees upto the post on all 4 sides. This ensures any water runs off the concrete and away from the posts, otherwise it will sit on top of the concrete and rot the post.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Thu Aug 18, 2005 7:37 pm    Post Subject:
Also what I find with metpost, it's not easy to line them up against the fence panel, depending on the ground condition as they can sometime twist as you bang it in or goes out of line.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
Fence post spikes 21 1040 Wed Sep 16, 2009 11:25 am
Erecting 8 ft fence post with spikes?? 28 1560 Thu May 15, 2008 9:35 am
Ground Spikes for a Rotary Airer 5 4460 Wed Jun 20, 2007 1:06 pm
Removing fence spikes 7 1800 Mon Dec 31, 2007 9:38 pm
Garden Arch... spikes or Postcrete??? 24 4560 Fri Mar 09, 2007 10:57 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
