Roylisa
Joined: 20 Aug 2005 Posts: 1 Location: United Kingdom
Posted: Sat Aug 20, 2005 12:05 pm |
I have a self closing chain which is attached to the door edge and the door frame.Problem is the screw plate has come off and the tension is too strong to replace
How can I do this? |
kevplumb
Joined: 18 May 2004 Posts: 23695 Location: Georgia, United States of America Thanked: 916 times
Posted: Sat Aug 20, 2005 2:01 pm |
pull it out and stick a small nail through the chain to hold it |
masona
Joined: 05 Jan 2003 Posts: 12352 Location: Essex, United Kingdom Thanked: 98 times
Posted: Sun Aug 21, 2005 8:31 am |
Is it this one?
If so, they normal come with a flat plate tool with a groove in the centre to do this, if you haven't got one, you can use a claw hammer to grip the chain to pull it out and carefully use a molegrip gently on the chain to take the tension off. You can also adjust the tension if you want by turning it anti-clockwise or clockwise.
Be very careful when doing this to prevent injury to your fingers |
