Compatible replacement actuator : myson mpe322
2 Dec 2010
Bradford
Does anybody have an idea which if any actuators are a direct replacement compatible with this myson mpe322 3 port actuator ( also called act322 I bleieve)
Is there a sunvic actuator that fits or another .
Cheers
As far as I know the Potterton / Myson are the only heads compatible with that body. They are not the best and you can buy the complete valve and head for £36. I would change the whole valve and fit a Honeywell.
I agree.
For a customer I would change the head as thats cheaper than having to drain and change the whole valve.
But for myself if I had the time then I would fit a Honeywell valve.
The motor only can be changed on the Honeywell ones but on the Myson its difficult and usually the plastic bits have failed anyway.
Another one to add to the Honeywell suggestion!
Easy to obtain new motors and heads if ever required.
Carl
I did manage to fit a Danfoss actuator to one of these valves once - BUT it was a lot of work including the need to drill new mounting holes in the valve face plate - not something i would recommend
when getting a quote for a new head ask for the price of a complete valve/head assy as for some stupid reason they are often cheaper when bought as a complete head/valve - you can simply take the new valve off and just use the head on your existing valve body ;)
Why do you want to have a different actuator? Why not simply buy another ACT322? I had to replace an ACT222 this week and my local Parts Centre had two in stock.
