Getting phase an neutral the wrong way round won't have damaged it, as for the RCD tripping, check you have the neutral in the right neutral block in the CU
I never did any work in the cu as the shower was just a replacement but i have noticed the MCB is 32A should i upgrade to 45A
Sorry the shower is 8.5Kw on 6mm cable through a 45A isolating switch
If the RCD is tripping then you've probably introduced a N/E fault somewhere - reversing Live & Neutral will not cause anything to trip.
32A is too small for an 8.5kW shower, but 45A might be too big for 6mm² cable - do you know where it runs, and if it's grouped with any others, or in conduit or insulation anywhere?
