Pressure build up in Sime Super 90 mkII combi boiler
9 Sep 2005
Manchester
Before I go into my problem, just want to say, what a good community this is. Now as I've buttered you up, could somebody please help me with my problem.
I found water spurting out of a small hosepipe hanging out of the bottom of my boiler. Presumably this is from the pressure release valve? I checked the water pressure and saw that it was about 3 bar, so released the manual pressure release valve and dropped it to 1 bar. Unfortunately, the next day it was back to 3 bar and spirting water again. I giggled my way through this forum (some of you really are mad'eads :LOL:) and have consequently done the following things;
1 - completely emptied the system, refilled it making sure no airlocks
2 - checked the expansion vessel - there is pressure and no water in it
3 - removed the filling loop type thing between the DHW and the CH - the braided pipe
None of this has fixed the problem. I'm now really stuck so was wondering if anyone has any other ideas before I make a call a plumber.
PS - I know someone will probably tell me that the boiler's a pile of bob (I don't need to be told this) but as we've got new princess in the house, can't afford a new one at the moment - and probably won't for decades come to think of it!! :cry:
Thanks for the reply Slugbaby. Suddenly I'm not giggling anymore. :(
Is there any way that this can be tested before I order one and is it difficult to change?
This is a pretty unusual fault and I only encounter typically one every year amongst about 3000 boilers.
If the pressure stops rising when the CW into the boiler is disconnected then there is another reverse test you can to.
Pressurise the boiler to two Bar and disconnect the cold feed and hot water out connections, if its the plate HE leaking then water will continue to drip out of the hot and cold connections on the boiler.
Tony Glazier
:eek: Well that sounds about right! I hear what you say about it being a rare fault, but I cannot think or find in the forums anything else it could be.
slugbabydotcom said:
Good news is that they are not that expensive for a boiler part
Brilliant, thank you for letting me know that one Slugbaby.
Thanks fellas for your replies and suggestions, they really are appreciated. Long live your generosity in sharing your knowledge and experience with others
Although its a pretty unusual fault its one which is quite easily identified and already I am pretty sure thats your problem.
Its better to do several tests to confirm its that before replacing parts though.
In the real world we encounter some extreme examples of stupid and unexpected things.
Once I diagnosed that there was a cold water connection into the hot water outlet from the boiler. This prevented the combi sensing any hot water demand. It was easy to diagnose but the landlord said there had been no plumbing changes made.
He was reluctant to let me look as I think he did not believe my diagnosis! I soon found it though! There was a bath mixer tap on which he had capped off the shower point and forcibly screwed the separate shower valves shut to stop the tenant using the shower and spilling water on the floor.
The tenant had turned the shower valves back on to use the shower but replaced the final cap after showering but left the valves turned on thus bypassing cold into hot.
This was a most unusual bath mixer tap! It had two taps for filling the bath and ANOTHER two valves for supplying the shower! First and last I have ever seen like this.
Tony Glazier
Makes my attempts at plumbing seem positively professional!!!
I used to be a working jeweller. Remembering how some items of jewellery were "repaired" still makes me somewhat flabbergasted. A large diamond - worth about £600 - superglued into a setting, chains "mended" with fuse wire or a bent paperclip. It doesn't surprise me that plumbers have similar unbelievable stories about what some bodgers have done. Still, you should be grateful - it keeps you all in work :)
Carl
PS thanks for the confirmation
I have inadvertantly (turning mains water back on whilst feed water tap to boiler system is open) sent my boiler pressure upto 3 bar. I see mention of a manual release valve in the post above, but no idea what it is or looks like... please...
Is it safe to use the boiler as it is
Do I need to somehow (how?!) reduce the pressure back down to just above 1 bar where it was?
All this caused by trying to fix a tiny weep on incoming main stoptap! Arghhh! Any advice or help please, thanks folks
:rolleyes:
Bleed about 2 li from a rad bleed screw to reduce the pressure to 1.5 Bar and do it immediately before you spoil the boiler.
Try tightening the gland nut on the stopcock ( the one around the shaft ).
Tony Glazier
Young and inexperienced owner here so please be gentle :)
I had a build up of pressure to about 3 bars, followed the advice and used the Red Release valve called 'Safety Valve' in the manual. Straight away the pressure dropped and went back into blue for a while.
But now the pressure is dropping very slowly and hasnt steadied. Pressure drops below 1 and i have to manually re-pressurise using the blue screws for cold water and C.H.
Checked outside and the discharge pipe is dripping water ao it must be constantly releasing but i cant figure out how to stop it!
Please could someone guide me how to steady the pressure and stop the leak?
The pressure relief valve will often leak after opening, due to debris on the valve seat. You could try operating it again and it may seat if you're lucky..otherwise would need replacing.
