Plymouth_Monkey
Joined: 11 Sep 2005 Posts: 4 Location: Plymouth, United Kingdom Thanked: 0 times
Posted: Sun Sep 11, 2005 11:29 am Post Subject: Dual Fuel Range Cooker |
I have a new range cooker (newworld spirit 110DF) coming and need to run a new cable from the CU to the outlet box approx 20-30ft away, the power ratings for the twin ovens and the grill comes to a total of 6.5kW (2.7 for Dual circuit grill, 2.1 for one oven and 1.7 for the fan oven). I need to know what rating of MCB to use in the CU and what diameter cable I should be using between the CU and the outlet box (which is a single switch type with no plug socket). The CU is a Steeple one 100A DP switch with 80A 30mA RCD. any help would be greatly appreciated
the outlet switch is 250V 45A DP
and the choice of MCB's I have is 32amp or 40amp
________________________
moderator
please note 10a which is here |
Adam_151
Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
Plymouth_Monkey
Posted: Sun Sep 11, 2005 12:34 pm Post Subject: price |
they are on offer at comet for £799 |
Adam_151
Posted: Sun Sep 11, 2005 1:50 pm Post Subject: |
I'd use 10mm² cable (will make sure its future proof*), I'd fit a 32A mcb, because the cooker takes less than this, and there is no addtional load from the socket to think about factoring in.
Make sure it goes
CU - > cooker switch -> cooker connection unit - > cooker
* 6mm² cable should be alright though
//cable sizes based on current carrying capability under normal conditions, factors such as derating factors for thermal insulation and bundleing, volt drop and, R1 + R2, etc, could affect cable size in certain situations, your mileage may vary. |
Plymouth_Monkey
Posted: Mon Sep 12, 2005 1:52 pm Post Subject: thanks |
thanks for all the info |
