Hello All
I am going to fit a tiled worktop in the kitchen. I will be using 9mm matt floor tiles. i have on order Mapei Primer G, Keraquick Flexi and Kerapoxy Grout.
what my question is, can i use 18mm T&G green chipboard flooring?. I have already fitted the chipboard. 2 layer (36mm) glued and screw at 150mm apart. Or should i fit a 6mm ply on top and glue and screw that down, then tile on to that. The reason i am asking is i have read that green chipboard should not be used on floors to tile on. But want to know if i can get away with it on a worktop as it won't be taking the weight and use a floor does.
all the best Martin
all the best Martin
