DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cable problem
This topic originated from the How to page called Choosing the correct size flex
Click here to return to the page called Choosing the correct size flex.
  View previous topic :: View next topic
Author Message
jjsblues
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 13, 2005 1:49 pm    Post Subject:
cable problem
Reply with quote Thanks
2years ago we fitted new bathroom we used to have an 8.5 shower we changed this to a 10.5 we had a qualifeid plumber in to do the work and he also fitted the shower well over the weeked the prd operated so we had an engineer out yesterday he fixed the problem then told me that we are running it on a 6mm cable and it should be a 10mm cable he also said we had the wrong fuse as well so he turn the shower off at the mains and said it was up to us if we wanted to switch it back on again don\\\'t know what to do we spent a lot of money on that bathroom and the thought of it being knocked about i find quite daunting but surely if we have used it for 2years with no problems is it safe to carry on thanks icon_cry.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Qedelec
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 13, 2005 2:52 pm    Post Subject:
How much damage do you think overloading a circuit will cause?
Just because you can swing on a rope one day, doesn't mean it wont break another.
__________________
"Shock me again and I'm gonna turn you off"
Life's a beach.
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 13, 2005 2:55 pm    Post Subject:
Re: cable problem
either replace cable or get a lower rating shower. or burn the place down. your decision
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Sep 13, 2005 3:39 pm    Post Subject:
Re: cable problem
Presumably this plumber was qualified in plumbing, not electrical installations?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Sandy Beech
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 13, 2005 3:47 pm    Post Subject:
Re: cable problem
Get a registered Sparks in to assess the situation and see if a new cable can be run without having to rip out the wall covering. For example can it be accessed from the opposite side of the wall?
Personally I prefer a mixer shower with no electrical involvement except for, maybe, a shower pump in an area that can be accessed.
__________________
Alex
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Sep 13, 2005 4:42 pm    Post Subject:
Electric showers do have their plus points, which will become more positive as time goes by..
__________________
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Tue Sep 13, 2005 4:53 pm    Post Subject:
I'm feeling dumb today... mind spelling it out?
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 13, 2005 5:00 pm    Post Subject:
[ignore]
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Sep 13, 2005 5:03 pm    Post Subject:
isn't our leccy generation moving more an more towards gas as the moment anyway?
electric heating sucks from an efficiancy point of view.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Sep 13, 2005 5:40 pm    Post Subject:
1) You only heat the water that you use, at the point of use. No losses from trying to maintain a store of hot water.
2) You heat the water by electricity. You do not burn any fossil fuels to heat the water, and ignoring for now how electricity is generated, it can be generated without burning fossil fuels.
Funny - I've not noticed waves of heat , or lots of noise coming from my shower, so I can only assume that nearly all of the energy being consumed is going into heating the water. If it's inefficient, where is the energy not being used to heat the water going?
__________________
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Sep 13, 2005 6:10 pm    Post Subject:
Up in smoke at the power station, noise at the power station, losses in transformers, cables and equipment, wasted heat at power station. Need i continue?
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Tue Sep 13, 2005 6:18 pm    Post Subject:
Our one is quite warm to the touch on the plastic caseing after use... the connections are starting to break down and get warm, the thing is past its sell by date too be honest, we have got a pumped tank fed one to replace it with, when by dad can be bothered to put the pipes in... ,at this rate, maybe should get a cheapo replacement electric one and change it as a short term measure before this one melts itself.
*sweeps part p under the rug*
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Sep 13, 2005 6:22 pm    Post Subject:
Wind and solar are a joke they can't meet demand and they don't have the load profile flexibility. They generate when the wind blows or the sun shines not when people actually wan't power.
Hydro is ok but has environmental problems of its own (particularlly if land is floody without clearing it first) and we just don't have many good sites for it left in this country.
nuclear has been basically killed off by the not in my backyard attitude. Also for various reasons nuke plants tend to be base load plant not start-stop plant intended to satisfy the peaks.
whats left? fossil fuel generation, its bad for the environment but no one power plant is bad enough for the environmentalists to target too much. Its also cheap to build and provided gas stays cheap its cheap to run and has pretty flexible output provided its well designed.
up the power station chimney, The losses have happened before it reaches you.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
External cable problem 5 120 Mon Nov 02, 2009 4:31 pm
wall cable problem 7 560 Mon Nov 13, 2006 9:28 am
Lighting cable problem 8 1100 Thu Nov 18, 2004 6:45 pm
titan electric shower cable problem 2 160 Tue Jul 14, 2009 6:38 pm
update to my telephone connection problem, massive bill :( 13 620 Fri Jan 19, 2007 11:10 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
