Hotpoint Aquarius WF560 - Flashing Wash Enhance Light
10 Apr 2012
Essex
Hello,
Just joined this forum.
I have a Hotpoint Aquarius WF560 Washing Machine.
On application of mains power, after several seconds, the On/Off light will 'flash on/off' and so will the 'Wash Enhance' light.
The machine will go part way through the cycle, stopping in limbo at the rinse and spin phase.
Any ideas what this fault is? Or what these error codes mean?
Cheers, Ben.
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light in your one error fo1 pcb gone ex pcb from here http://www.emwelec.co.uk/index.php?action=category&id=
Hello rocks1,
Thanks for your reply.
You mentioned I need a new PCB.
Is that because the Heater Relay has failed, inline with f08 light 1?
I'm assuming light 1 is Wash Enhance?
Cheers, Ben.
Yes correct. But just test heater first should be 25 ish ohms.
Hello rocks1,
Been away from home over the last week, need to get back on the case with this.
Could you tell me were the PCB is situated within the machine please?
And the best way of getting to it?
Cheers, Ben.
