DIYnot
Local | Network
   DIYnot > Forums
Local | Network
memera 2000 fuse box
Goto page 1, 2  Next
Author Message
shandyf
from United Kingdom
PostPosted: Thu Sep 22, 2005 7:20 pm Reply with quote
Hi all,
Does anyone know where I can buy a new "fuse holder" for a memera 2000 fuse box. I want to wire in a new plug socket ring to my existing fuse box and I have one spare slot available for what I call a "fuse holder"!! It's the thing that you can pull from the box to isolate the ring and/or change a fuse (aprox 2inches high and 0.5inches wide)
Also, what amp fuse should I use (13?)??
There will be 12 double sockets in a ring hanging off it.
Thanks!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1969 times
PostPosted: Thu Sep 22, 2005 7:26 pm Reply with quote
Are you really sure that you have enough knowledge and experience right now to be doing this?
Also, are you aware of Part P of the Building Regulations, and the fact that as this is notifiable work you are required to notify your LABC about it before you start?
Back to top
 Alert Moderators
shandyf
from United Kingdom
PostPosted: Thu Sep 22, 2005 7:29 pm Reply with quote
No, I'm not sure.
The main thing here is that I don't know the specific name for this "fuse holder" - give me a break.
Yes - I DO know that I need to do things differently with building regs nowadays and I have it covered with a qualified electrician.
I am simply trying to get this "part", i.e. the "fuse holder" bought in advance so he can just arrive and do the job.
Can you possibly help me at all?
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 2 times
PostPosted: Thu Sep 22, 2005 7:33 pm Reply with quote
yes. let the spark get the right stuff. and for a start, its not 13A.
Back to top
 Alert Moderators
shandyf
from United Kingdom
PostPosted: Thu Sep 22, 2005 7:36 pm Reply with quote
thanks very much
Back to top
 Alert Moderators
ryanj
from United Kingdom
PostPosted: Thu Sep 22, 2005 11:50 pm Reply with quote
Hmm.
While we're on the subject.
Do these consumer units come in metalclad?
Has anybody used them, what do you think of them?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 473 times
PostPosted: Fri Sep 23, 2005 1:11 am Reply with quote
Yes, Yes and Good.
Back to top
 Alert Moderators
kai
from United Kingdom
Thanked: 42 times
PostPosted: Fri Sep 23, 2005 7:30 pm Reply with quote
It looks like you need a B32 amp MCB to fit the memera 2000 consumer unit. They clip onto the din-rail, and are available for many electrical wholesalers.
Back to top
 Alert Moderators
baldelectrician
from United Kingdom
Thanked: 6 times
PostPosted: Fri Sep 23, 2005 8:00 pm Reply with quote
that's why I buy MK consumer units,
They make an adaptor kit (retrofit kit) to fit new style MCB's into the old sentry units. (these old units were out at lease 15 years BEFORE memra 2000) but MK still do spares.
As I have said before you get what you pay for.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1969 times
PostPosted: Fri Sep 23, 2005 9:13 pm Reply with quote
And with MK that's flimsy cases, dodgy bus-bar covers, MCBs that won't sit upright on the rail.....
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 423 times
PostPosted: Sun Aug 05, 2012 4:52 pm Reply with quote
Sticking with the correct make means you have a fully type tested consumer unit which is a better idea, I think the OP might have got it fixed now though as the post was made in 2005
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1095 times
PostPosted: Sun Aug 05, 2012 5:05 pm Reply with quote
Yep using some other manufacturers kit is going to leave you with a non-compliant installation.
For the sake of a few quid, buy the correct part, and leave yourself with a safe, compliant installation.
Oh and the day I start taking the advice of 'the guy from wickes' over specific instruction from the manufacturers is the day I need to start taking a long hard look at where my life has gone wrong.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 158 times
PostPosted: Sun Aug 05, 2012 5:34 pm Reply with quote
IIRC, the memera 2000 had two revisions. The earlier one having wider busbar tabs. You are meant to use memshield 2 commerial range if you need a breaker to fit the earlier revision. I cant remember which range for the later revision.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 973 times
PostPosted: Sun Aug 05, 2012 6:12 pm Reply with quote
note the date of the thread PostPosted: Fri Sep 23, 2005 9:13 pm
Back to top
 Alert Moderators
baldelectrician
from United Kingdom
Thanked: 6 times
PostPosted: Sun Aug 05, 2012 6:24 pm Reply with quote
I know this is from 2005, but MK have went downhill since then
I don't use MK now as they are (in my opinion) cheap, flimsy and prone to manufacturing defects. This applies to the acessories and the consumer units
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Memera 2000 fuse box - power sockets out 5 300 Tue Dec 30, 2014 1:47 pm
Shower / Memera 2000 fuse box trip 8 900 Thu Jun 03, 2010 6:19 pm
memera 2000 3 440 Wed Oct 28, 2009 12:56 pm
memera 2000 shower installation 2 120 Wed Oct 26, 2011 10:28 pm
Memera 2000 Consumer Unit 13 2040 Sat Jul 02, 2011 3:45 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
