DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
eletrical fault
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
wayne-o
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 25, 2005 6:32 am    Post Subject:
eletrical fault
Reply with quote Thanks
in my bathroom i have aceiling rose,there is power to the light fitment,when i turn the light on and off it recieves the 240v but it will not light up the blub....!
yes i have tried a different bulb. when i shake the fitment about the bulb flickers, or used to now it does nothing,this sugests to me that maybe a cable is broke, i have a tester but do not no how to test the wires any help would be greatful
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sun Sep 25, 2005 9:27 am    Post Subject:
Sounds like a new light fitting to me.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Sep 25, 2005 9:30 am    Post Subject:
What sort of tester are you using?
Where are you measuring the voltage - at the terminals of the fitting or inside it where the bulb makes contact?
The fact that wiggling it makes, or used to make, it flicker on and off sounds more like a dodgy fitting than a broken cable.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Sep 25, 2005 9:35 pm    Post Subject:
Some fittings use solid strand conductors that can fracture, but this can be eliminated by gently tugging on the connections.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
wayne-o
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 29, 2005 10:59 am    Post Subject:
its a brand new fitment (rose) and pull string....any thoughts now....?
i have a pen tester that you use your body for earth i have tested it at the rose and the pendant when i pull the switch cord it registers 240v and disappears when i pull it off
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Sep 29, 2005 1:58 pm    Post Subject:
Throw it away.
Buy a proper multimeter.
Repeat the tests.
See if you really do have a supply getting there.
__________________
Back to top
 Alert Moderators
pdcelec
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 29, 2005 5:52 pm    Post Subject:
I would prefer not to use my body for earth. I would much rather use the correct equipment and let the earth cables do the earthing. I wonder why the main earth is a piece of cable with a csa of 16mm?
Back to top
 Alert Moderators
wayne-o
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 30, 2005 9:34 am    Post Subject:
i have a multi meter but do not know how to use it what setting do i need it on and what wires do i touch to test please advise......
thabkyou for your time
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Sep 30, 2005 10:18 am    Post Subject:
have you not read the instructions?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Sep 30, 2005 4:03 pm    Post Subject:
How much do you know about electricity?
Basic stuff like potential difference, current flow, resistance, the difference between (and relationships between) voltage, current and resistance?
__________________
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 30, 2005 8:34 pm    Post Subject:
wayne, if your neon screwdriver is lighting when you switch on and going out when you switch off, with the good lamp in see if the blue neutral side of your fitting also glows this would suggest a broken neutral connection. if it does glow take out the lamp if it stops glowing with the switch on its definitely a broken neutral
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Mounting eletrical box 2 180 Tue Jun 03, 2008 12:36 pm
Eletrical Equipment - drawing too much power - how to test ? 7 500 Tue Jul 10, 2007 2:11 pm
hi-fi power supply fault? 31 800 Sat Jul 19, 2008 10:03 pm
Fault Finding On A Ring Main Circuit 9 580 Tue Jul 29, 2008 9:44 am
Interesting Fault. 20 600 Tue Jul 29, 2008 7:56 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
