DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Spotlight not working
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
sparkes
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 26, 2005 1:29 pm    Post Subject:
Reply with quote Thanks
I have a spotlight in the bedroom which when turned on flickered then blew bulb. I have replaced the bulb but now it does not work (I have tried other bulbs also). It did not trip any of the other lights when it occured - any ideas???
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Mon Sep 26, 2005 1:40 pm    Post Subject:
Have a look down at the inside of the light fitting at the bottom, where the contact makes with the end of the bulb. There may be a black spot that was caused when the other bulb blew. You'll need to clean that off so that the bulb can make proper contact.
You could use a flat bladed screwdriver or a little sandpaper glued to the end of a pencil (the blunt end obviously).
Make sure the juice is off though!
Good luck,
Gcol
Back to top
 Alert Moderators
sparkes
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 26, 2005 2:32 pm    Post Subject:
Thanks for the advice. I have looked and there did appear to be a black mark but it would not come off. I have looked at another spotlight nearby (a working one) and the same markings are on that one. Any other suggestions???
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Sep 26, 2005 5:02 pm    Post Subject:
sounds like something got burnt out, take the light down and have a look, may be less hassle to get a new light
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Mon Sep 26, 2005 5:59 pm    Post Subject:
What you were looking for was a black mark with a texture like coal. You only need to make the surface smooth again (it doesn't matter if it's still black).
If you've tried a known working bulb and it still doesn't work then, like Breezer says, you're taking it down and checking it out.
If you just got a new bulb and tried that, make sure that there's not a clear lacquer type substance over the bulb contact. I've had that stop a bulb from lighting before now - I assume it's just flux and is very easily sanded away.
You could try lifting the contact in the light fitting (the one that touches the end of the bulb) so that it makes a harder, better contact when you screw in the bulb.
As always, with the juice off.
Cheers,
GCol
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon Sep 26, 2005 6:58 pm    Post Subject:
Is it an edison screw lamp? I have known the neutral contacts on a ES lampholder to bend back causing bad contacts. Just a thought, worth checking anyway.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Sep 27, 2005 11:06 am    Post Subject:
Only if you've wired it incorrectly icon_wink.gif - the threaded outer is supposed to be the neutral on ES lampholders... icon_lol.gif
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue Sep 27, 2005 12:17 pm    Post Subject:
Some ES lampholders have neutral contacts that flatten with use too...
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
sparkes
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 27, 2005 12:57 pm    Post Subject:
Thanks for all your info but sadly still not working!!!
Think I am going to have to remove the spotlight now. As I have never done this before do I just remove the two small screws which are visible when the bulb has been removed and then ease it from the hole?
When removed is there anything specific to check for before purchasing a replacement?
Thanks in anticipation.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
halogen spotlight connection query 5 240 Thu Apr 03, 2008 8:04 am
Adding an additional spotlight 2 180 Fri Apr 18, 2008 3:30 pm
replacing standard ceiling light with multi-spotlight 5 480 Sat Apr 26, 2008 7:46 pm
Low energy outdoor spotlight 8 540 Thu May 01, 2008 10:39 am
Lighting cable too short to fit new spotlight 2 1100 Mon Jan 28, 2008 5:19 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
