pmbynini
Joined: 26 Sep 2005 Posts: 1 Location: United States of America Thanked: 0 times
Posted: Mon Sep 26, 2005 7:30 pm Post Subject: Need to remove melted candle wax out of vase |
Will you please give me a home remedy to use to remove the melted candle wax out of my vases used for wedding decorating. |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Mon Sep 26, 2005 8:46 pm Post Subject: |
vases upside down in a warm oven? __________________ Do you like music Mr Finch?
Forum = Opinions |
nstreet
Joined: 22 Nov 2003 Posts: 1761 Location: United Kingdom Thanked: 0 times
Posted: Tue Sep 27, 2005 9:59 am Post Subject: |
Fill with boiling water until overflowing?
How about lining with something to catch the wax in the first place, would save a lot of cleaning.  |
Nige F
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
User665
Joined: 30 Sep 2005 Posts: 3 Location: Canada Thanked: 0 times
Posted: Fri Sep 30, 2005 9:24 am Post Subject: |
Depending on the size, and thickness of your vase, you could put it in a container/tub of boiling hot water, and the wax should be easy to move after about 30/mins. If not, if the wax is thick, take a woodburner with a hot knife attatchment and cut it into small enough pieces, tap it lightly until the pieces come out. If none of this works, post back and i might have some more ideas.
Hope this helps
______________________
modrator
post locked to prevent hi jacking |
